Old 07-17-2018, 04:20 PM
jaykhjr jaykhjr is offline
Default Brackets, carb question, and general pics of my "O"
Posting some pics. Looks like the wire to connect the carb to the control unit.
Also anyone know what the brackets under the tractor are for? Mower deck?
And more brackets on the front... no clue what these are for.
Rear battery holder pic because it made me laugh.
Old 07-17-2018, 04:23 PM
More pictures
Old 07-17-2018, 04:26 PM
Even more pictures
Old 07-17-2018, 05:51 PM
Not sure what you mean about the "wire to the control unit".... Unless you are stating the throttle control rod to the governor arm is missing. It in fact is....
The brackets behind the front axle on the frame are for a mower deck.
The ones on the side of the grille housing are whats left of the steel mount for a rubber Grote work light someone installed, and I guess ripped off. There were lights on it....
This thing is pretty rough.....
But, we've seen worse.
Old 07-18-2018, 01:33 PM
I will remove the mounts as I dont have a cutting deck and dont plan on using old light mounts for anything.
I ordered a carb rebuild kit (why not...) and a spark plug and Brillman wire for it.
Any tips on getting the new cable the correct length between the governor arm and the throttle? Is is safe to use some small stainless braided cable I have laying around the workshop?
Old 07-18-2018, 01:44 PM
No, no, no.... you have to get another control rod. It isn't a cable, or a wire. It is a specific length part. Ask around, or look up the part number and search. They may still be available new, but I was thinking that one is NLA from Kohler, but that doesn't mean they are non existent new. Just not as easy to order. I'm sure you can find one.
Old 07-18-2018, 01:56 PM
Chad126's Avatar
Chad126 Chad126 is offline
jaykhjr,
This is what you are looking for (circled in dark blue). These are not generic across all kohlers, so be sure to get the one for the O (K161).
"Equality is about giving everyone an equal chance, not about giving everyone an equal result."
1971 126 w/ Brinly Sleeve Hitch, Plow, Discs, and Cultivator
http://www.onlycubcadets.net/forum/s...ad.php?t=50159
Old 07-18-2018, 01:58 PM
I PM'd you a link. Not cheap but I think it might be the right part.
Thanks again sir!
Originally Posted by Chad126 View Post
jaykhjr,
Thank you! I really Appreciate it!
Old 07-18-2018, 02:01 PM
Chad126's Avatar
Be sure to do your own homework on your engine model because I don't want to be responsible for you buying the wrong part, but I believe this is the part. you just need to cross check it.
https://www.ebay.com/itm/Genuine-Koh...-/231861482813
