Old 07-18-2018, 06:11 PM
CedarBranchCoastie's Avatar
CedarBranchCoastie CedarBranchCoastie is offline
Angry Kohler rocker arm issues
I have a Cub I bought in 2014. It has 210 hours and the rocker assembly in both cylinders went bad. Has anyone else had this problem. Is this something common to Kohler 2 cylinder horizontal shaft engines? I bought w Cub with the Kohler because Kohler is supposed to be the best. Did I make a big mistake?
Old 07-18-2018, 06:18 PM
What model tractor??
"Cub Cadet with a two cylinder motor" isn't very specific...
Yes, some of the Kohler engines had rocker issues. Usually you fix them and it isn't an issue anymore. They are still a good engine. I will say, usually rockers make noise when they start to get loose. How long did you run it with it clattering?
Old 07-19-2018, 08:52 AM
What Kohler engine does it have? The Kohler commands are great engines but the Kohler courage are a POS and known to have multiple issue including the valves.
Old 07-19-2018, 05:06 PM
In order to answer your question we need to know what model tractor you have and what engine it has.
