Old 07-28-2018, 10:53 PM
Originally Posted by yettrbomb View Post
So typical celebrity??
Apparently so, lol.
Old 07-28-2018, 11:06 PM
bllwnkl's Avatar
bllwnkl bllwnkl is offline
By the way, since I bought this tractor as my snow pushing tractor, what's a good front tire for that purpose or does that really matter? I have chains and weights for the rears.
Randy
Old 07-28-2018, 11:33 PM
On snow and ice, it really doesn't matter. Oh, a rib tire will make a difference, but I'm not sure it's worth the cost. I used to use my Cubs to clear parking lots. Like several... and driveways. Never had anything other than turfs on the front. Know your limits, and use them to your advantage. As a note, I've ran and used all kinds of tractors in the snow. Chains make all the difference in the world. Steering.... well, it's best if you have something with individual brakes.
Old 07-29-2018, 10:18 AM
jbrewer's Avatar
jbrewer jbrewer is offline
Sounds just about typical, yes.
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 07-29-2018, 10:47 AM
Billy-O's Avatar
Billy-O Billy-O is offline
The narrow rim tires work better for me. Tried it both ways.
Plow blade
#2 Cart
QA36 snowthower
Old 07-29-2018, 10:49 AM
I agree. Best tires I've used in the snow were narrow tri ribs, the wide tri ribs suck.
Old 07-29-2018, 10:52 AM
DeltaCub's Avatar
DeltaCub DeltaCub is online now
The 1250 bllwnkl bought has 3/4" axle spindles so he can put on "skinnies" very easily.
Queen Of The Quietlines!
Old 07-29-2018, 11:33 AM
cooperino's Avatar
On snow, where we get real snow fall, NY 35" average, Canton Ohio 40" average. The narrower the front tire the better. Narrow tires cut through snow. Wide tires sit on top.. It would not make much difference in climate like Oblong Illinois where they only see about 12" per year on average.
On Ice, narrow or wide you will slip and slide LOL
Old 07-29-2018, 02:33 PM
On a tire that is only 12" tall, it doesn't matter if you get 3" of snow at a time, or 200". You will have the same issues. Geography plays no part in it, unless you live in the south where no snow falls. Ice is ice, and snow is snow. I never saw any advantage, wide or narrow tires. They will all slide on ice and snow. 90% of how the tractor handles, is dependent upon the operator.
Old 07-29-2018, 02:43 PM
cooperino's Avatar
Height of tire has no bearing on this particular issue. Coming from a snow state and having plowed snow for 30 plus years, I can tell you narrow tires perform better in snow. I stated ice makes no difference. I left out however, Here it is still common place to add studs to tires. In that case you could combat ice some
And 3" vs 10" is a different ball game let alone your 3" vs 200".. lol
