Old 08-04-2018, 02:02 AM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Originally Posted by Gravel Road View Post
Hello everyone. New to the site, but thought I'd start a thread on my 123. This will be a slow project that I've been putting off until my new shop was complete.
A little background: this was my late father-in-laws tractor that he used in a cattle operation. He was paralyzed in the Korean war and this little tractor was low enough for him to get on from the wheelchair.
The tractor has been sitting in a corner of the dirt floor barn for the last 35 years or so, and is a little rough-lol. It has a front end loader in pieces and a tiller on the back. I'd like to get it going and use it to till the garden and move a little dirt when my Kubota tractor isn't available.
In all it's glory!
That is quite a find!! Always nice to have the story to go with the machine. That makes the process more enjoyable and fulfilling for me in the end! You have come to the right place for help! These little tractors all have a personality and are great fun to work on and use.. they tend to become members of the family around here!!
Please keep us posted! Your father in law would be proud you are saving his tractor!!
Jay
Proud owner of the following:
Old 08-05-2018, 11:08 PM
Gravel Road Gravel Road is offline
A little progress this weekend.
Changed plans and decided to strip 'er down. Motor removed to get the loader off a little easier. It went pretty well with a few exceptions.
-Steering wheel removal. Man, I've been soaking this with Kroil for days and it still won't come off with a 3 jaw puller. The plastic center part of the wheel broke off, as I didn't realize how much plastic there was. Heat will melt out the plastic bushing below, and I need to see if they are available. I'm going to try some freeze spray on the stem first.
-Motor is HEAVY! Going to use this as an excuse to buy an engine picker to man handle it.
-Cracked frame under the engine. Not sure if this is common or not, but expect that it was due to hard usage with the loader. I'm really surprised that the frame isn't a little heavier.
-Bearings are very loose in the front wheels. Will need to mic and see if the bearings are shot or the wheels got worn out under heavy loads.
Old 08-05-2018, 11:45 PM
john hall's Avatar
search the forums for steering wheel removal, quite a few homemade ideas posted over the years.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 08-06-2018, 12:09 AM
jaynjeep's Avatar
Since you already broke the plastic part of the wheel i'd just heat the hub.. heat and a puller will bring it right off.. the bushing underneath is readily available or I have been told a front wheel bearing works in it's place..
Hard loader use is likely what broke the frame.. IH never designed it to take that kind of use.. all the loaders were aftermarket.. weld it up and reinforce best you can.. it lasted this many years so a good repair and you will get many more!
Your progress is looking really good! Sure is fun working on these old beasts!
Jay
mortten mortten is offline
Cracking in that area is common.
Doug
QA-36A
42" blade
Old 08-06-2018, 09:45 AM
farmall fred's Avatar
farmall fred farmall fred is offline
Making good progress. Glad you decided to tear it down all the way. The cracked frame is common on the older ones. I have had three that I had to weld that area and none of them ever had a loader mounted. One was a 71 that only mowed grass with 38 inch deck. Keep posting progress pictures as you move forward with the rebuild.
Old 08-06-2018, 11:39 AM
My guess it is caused by slop in the 'C' channel where the main axle pivot pins the axle to it.
Back and forth movement, if not tight when hitting bumps or obstacles would, I think, could cause that damage if not more, over time.
And it would be magnified of course with a loader involved.
Luckily, I did not encounter this issue when I restored my 149/DanCo unit last winter.
Old 08-06-2018, 09:57 PM
Thanks for the info guys. I need to pull the front axle and decide how to best repair the frame. Lots of different stresses concentrated on the poor little frame in that area.
This 123 will see pretty light duty compared to how it was used in the past, so the repairs should last a long time.
Old 08-26-2018, 11:03 PM
Default Hydro lever removal?
Okay, the hydro lever is kicking my butt, as it's stopping the steering column bodywork from coming off. It seems like I've got about everything disconnected, but it doesn't want to come out due to the steering shaft/hydro lever relationship. I've disconnected the bottom, but no luck. Any help?
Bought an engine hoist to assist in the lifting duties, and it's a big help. Raised the whole frame up and let the differential drip dry. It made disconnecting the hydro lever pretty easy on the bottom side.
Old 08-26-2018, 11:13 PM
Standing the whole tractor up is handy. Not sure it's necessary.... but that's ok. Whatever is easiest I suppose.
Pull the bolts out of the column, and pull it out the bottom. Then you can get the dash off.
Take the 6 bolts out of the rear and just take the transaxle out. Pretty easy, and you don't have to hoist it all up in the air like that just to drain it. Just set it over a bucket.
