Does anyone have the measurements on building a #40 box blade. See lots of pics but no measurements. Thanks
Which dimension do you need? Width, depth, height? Your fabricating the box right? Best thing to do is figure out close to dims on the box then you should draw out the rest with your own dims. If your looking to copy one to the t I'm not sure how to help you.. at that point may as well just buy one
I would like all the dimensions if possible. Surly someone on here has one and could take some quick measurements I hope. Looks like a good design so I don't want to reinvent the wheel sort to speak. Also wonder if the blade is lower then the sides or even with sides? I have seen both. Making one will be cheaper then buying one.
I am not so sure about that, I mean its cool if you want to build one but between time and materials I doubt it would be any cheaper. Heres a brand new one that looks pretty well built. 1/4 steel sides and 1/2 steel supports. Looks pretty stout. Hes asking 500 Buy it now. I would think you could find a used one similar to this for half that
Edit,, Even better, https://www.northerntool.com/shop/to...1185_200311185
Coop, he wants to copy a #40 IH box blade. The likes of which is not made anymore. Yes, you can buy a cheap flimsy one, but nothing as well made as a #40.
OP: Contact member Mike Masheris. He builds reproduction ones. Perhaps he will build you one, or get you what you need. Alvy linked to one of his threads on building them, in your other thread. |
Is that the same guy as from this thread?
https://www.onlycubcadets.net/forum/...ead.php?t=8708 Found another thread here from same guy that apparently built a bunch of these https://www.onlycubcadets.net/forum/...ad.php?t=12035
Mike made some beautiful repo ones as J-mech stated. I purchased one from Mike a year or so ago. great build quality and a nice piece to have.
I think we all got yellow fever at this point. |
These are the dimensions that I got by email from a fellow member;
Width = 40" (IH40) Sides = 14" at peak of the curvature Height = 12" Drawbar = Set 11" (on center) from back of bucket, and 5.5" from top of bucket. This is the box blade I keep saying I'm gonna build; https://www.onlycubcadets.net/forum/...412#post189412
Thank you very much
| Thread Tools | |
| Display Modes | |
