Old 08-26-2018, 05:29 PM
Timmy2j Timmy2j is offline
I suppose I should also ask the question that I don’t want to ask. Assuming the fix requires splitting the rear end, is it worth fixing? Or am I better off just throwing that money toward another used unit (preferably with gears, based on this experience)?
Old 08-26-2018, 06:42 PM
I don't think you understand. Buying a gear drive tractor doesn't change anything. It still has splined axles and hubs, unless you get an older Cub, then it will have a different set up entirely.
If the axle splines are still good, get a new hub. It's likely you need both though. I would look for a used transaxle. Or, go buy a Cub Cadet made before 1994 or so.
Old 09-07-2018, 04:44 PM
Got the report from the repair shop today. They pulled the transaxle and opened up the case. One of the large internal gears was broken in half and the other large gear had a hairline fracture. A couple of the smaller gears were ground down pretty well. So after $290 in parts and 5 hours of labor she will be back on the grass.
Old 09-07-2018, 07:04 PM
Good to hear, start it up and check it out at the dealer before it leaves their property.
Up to 534 and counting...
Tags
gtx2100, hydrostatic, transaxle, transmission
