Old 09-23-2018, 07:52 PM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
Is the clutch/brake pedal switch connected? Is the little metal tab on this linkage in place?
Queen Of The Quietlines!
Old 09-23-2018, 07:56 PM
Just as a note, he says he has no power on anything he has tested..... I find that hard to believe. Unless the battery is dead. Ought to be power somewhere.
Old 09-23-2018, 08:05 PM
Tim338 Tim338 is offline
Yes the clutch/brake switch is conected. The battery isn't dead the voltage is at 12.48 volts. Yes, believe it or not no power to anything. I left it for today and I'll get a fresh perspective next time I get a chance to work on it. Very frustrating.
I think he may have the wires on backwards on the starter solenoid.
Up to 534 and counting...
Old 09-23-2018, 08:50 PM
Oh, more than likely.
That should have been painfully obvious with a test light, a meter and the wiring diagram....
Thank you I will check.
Old 09-23-2018, 09:56 PM
Yep, what he said. Put that control wire on the common side of the solenoid and you’re in binness!
Old 09-23-2018, 10:06 PM
I don't understand all of you snide comments. I thought the purpose of this forum was to talk about cubs and learn a little about them. You know share a common interest...... Anyway thanks everyone for giving me some ideas on how to remedy my problem.
Old 09-24-2018, 12:45 AM
Vrobert's Avatar
Vrobert Vrobert is offline
That sounds familiar.
Think of this forum like playing a round of golf where novice players are attacked by gators but never really injured. Some enjoy the sport and stay here, but others look for greener... uh, tractors.
Rusty 149 project with:
QA42 snow thrower
38" deck
Barn fresh 1811 with:
44c mowing deck
QA42A snow thrower
42" snow blade
Old 09-24-2018, 05:37 AM
Tim:
Sorry, for rude or snide comments.
(A) Download the Wiring Diagram for the Wiring Section (page 5) in the Technical Library.
(B) Once in hand, examine your new harness to make sure your tractor is wired as indicated in the diagram.
(C) If you are sure, the tractor is wired correctly, then it is time to dig out a meter, either an analog (VOM) or a Digital (DVM)
(D) With meter set to read DC Voltage, at least 20V, connect the meter Black lead to the Battery Negative Terminal.
(E) Starting at the Battery, with the meter's Red lead, start probing at the battery and make sure you have 12V. With diagram in hand, work in a forward sequence (per diagram), until you find an absence of 12V.
Let me know what you find.
