Old 09-30-2018, 02:34 PM
Tom Dowling Tom Dowling is offline
Default kt17 II fuel pump gasket or o-ring?
Simple question about new fuel pump comes with fiber gasket and rubber o-ring gasket. Which one would be best to use? The old pump had two fiber gaskets stacked on each other. I am leaning towards using the fiber gasket what do you think would be better? Thanks for your opinion which I highly value. Tom D.
Old 09-30-2018, 03:43 PM
Read the paper that came in the box with fuel pump. It tells you. Or at least every fuel pump I've ever bought came with instructions.
Old 09-30-2018, 03:46 PM
There were no instructions to my dismay, thanks for the reply.
Old 09-30-2018, 03:57 PM
Must have bought a cheaper one.
Gasket is to bolt it up to rough cast surfaces. O-ring is used if the mount is machined.
Old 09-30-2018, 04:03 PM
I use the o-ring on all mine and never had an issue.
Old 09-30-2018, 05:35 PM
I like the "O" ring as it stays leak proof on those plastic pumps.
The paper gasket sometimes leaks and needs re tightened, not the easiest thing to do on some engines.
Glad they went to the O ring.
Clean the block surface,
install with "O"ring and torque to 40-45 INCH pounds, do not over tighten.
(as per instruction paper provided by
Kohler)
Old 09-30-2018, 06:00 PM
john hall's Avatar
Put on 2 aftermarket pumps in the last couple years--1811 and 782. Same supplier, aftermarket pump with a ton of fitting combinations. No issues with the O-ring so far. Did not torque anything.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 09-30-2018, 08:04 PM
Thanks all for the input, I went with the o-ring, seems fine.
Old 09-30-2018, 08:45 PM
The KT has a machined surface so.....
