#41
I read the procedure on how to adjust the govener I’ll give that a shot and see can’t hurt at least lol.
#42
Well some bad new the Governor gear is shot. Adjusted to the way the kohler repair manual wants and it just wants to take off i just cut the ignition and closed the throttle by hand. I picked up a 551 blower today so now i am kinda committed to this machine.
#43
Just to be sure: you adjusted the governor counter clockwise wile holding the throttle lever at carb against the stop (wot) and re tightened it this way? |
#44
Yes sir i even adjusted to three time to make sure i didn't mess up i printed the page and kept re reading it. If i feel the gov lever when it starts it doesn't even attempt to pull the throttle close it just goes WOT and stays even it the throttle is the idle position. I'm gonna pull the back plate off tomorrow and inspect the gear. |
#45
#46
Hopefully you did not pay a lot for the 1864.
#47
More then I probably should have I’m sure, Thats what happens when you buy on want and not logic.
#48
#49
I need to replace the PTO and my tractor has the older style, Can i upgrade to the newer style as they are cheaper?
#50
https://www.onlycubcadets.net/forum/...ad.php?t=45466
| Thread Tools | |
| Display Modes | |
