Old 10-31-2018, 09:43 PM
SS5150's Avatar
SS5150 SS5150 is offline
What do I need to be looking at when it comes to spindle bolts? What/how does it wear out there, and how can I repair it?
Thanks
Actually I apologize Dan, when I typed that up I didn't realize the NF's have a different spindle than the WF's. The WFs have a spindle bolt through the axle bushing, and that bolt clamps the spindle on top and bottom (so that the bushing rotates in the axle housing). Mine were left loose, so my spindles and spindle bolts had a ton of wear, as they basically rotated/vibrated against each other. I bought a grade 8 bolt through McMaster and cut it down and drilled it for a cotter pin.
Looking at the 147 steering you won't need to worry about that. As long as your spindle feels snug in the axle housing. Looking at the 147 front axle diagram, it doesn't show a separate bushing for the spindle to ride in.....I can't say as I haven't worked on a NF, but that seems odd to me. Someone with NF experience will have to advise on that.
RUN IN THE RED
1872 project
Cub Cadet Pro Z 560 L
Old 11-01-2018, 08:17 AM
Ok; I pulled the exploded diagram and I found the bolt issue for a WF. Once I start actually getting my hands dirty on this I’ll see what I need and go from there. Thanks for the clarification.
Old 12-03-2018, 05:31 PM
AL Farmall Boy AL Farmall Boy is offline
did you ever round up a parts list and order from McMaster? I have a 1450 wideframe (quietline series) that I am restoring and need to do exactly this to. Would be easy rather than trying to chase down part numbers and sizes.......IF your parts were the same as mine.
Old 03-19-2023, 10:21 PM
GERKS 149 GERKS 149 is offline
Anyone ever come up with the part numbers from McMaster? Working on my 1250 steering issues. Thanks
Mark
109, 149, 1250, 1450
