Coops would be good too if you have room on the left side of the cab or mount it on the outside on the roof.
The type of box i have would have to be inside the cab. Outside would cool to quickly. The air would be cold before it got to you. The core just doesn't have enough capacity. Also the ones i have are used on systems with 3 or more gallons of coolant. The kubota system might not have the capacity of coolant to keep the core happy. Welcome to try one tho.
Well then cut it in half and it will use less coolant.
You are like me, it is a Kawasaki not a 3 pin driver.
I wish I had a longer cab. My high back seat hits the rear glass even with the seat all the way forward. Wanna trade?
Don't have a 3205 so don't know how it's designed. Cart before the horse type situation? Do I get a 3205 without knowing if it'll work and make the best of it, or ask questions first....and then close my ears to what I don't want to hear and buy one anyway? ![]() Back corner? So you're thinking of running coolant lines from front to rear? Isn't that too long for a cooling system / engine that small? |
Surpluscenter.com has what your looking for. In expensive, compact. Exactly what you need
3240 870hrs - 48" 289 deck, front hitch, 3 hyd circuits, 54" blade w/hyd angle, 45" 2-stage snow blower, Sims cab, 5 42# suitcase weights and 70# rear wheel weights GT3204 207hrs - 48" 289 deck, 45" 2-stage snow blower, 54" blade and angle cylinder 3204 580hrs - 48" 289 deck - Parts Tractors - 3208 560hrs (rusty) 3 hyd circuits, 3pt hitch, 44" deck - 3165 rust free roller 1650DH 54" blade, Xtreme cat-0 3pt, 44" deck, filled 23x10.5-12 Tru-Powers |
| Thread Tools | |
| Display Modes | |
