Old 12-13-2018, 11:19 AM
RicochetFord RicochetFord is offline
Default Hydro creep at shut down
I have repaired the trunion, adjusted for neutral and tightened the tensioner on the hand lever and solved all of the issues associated with those items.
However I am still getting a creep or loud whine from the hydro if the brake is set and the engine is idled down or shut off.
Is something still slightly out or is this another issue?
I know one of the relief valves is weeping around the button, would that cause this issue?
Old 12-13-2018, 11:30 AM
GERKS 149 GERKS 149 is offline
I have had the same issue. Was resolved by adjusting the hydro a bit more.
Old 12-13-2018, 12:26 PM
Thanks. Would that be adjusting on the cam pivot plate some more?
Old 12-13-2018, 03:11 PM
Merk Merk is offline
There is a bushing in the damper plate that may have some wear and causing problems.
It's number 8 on this page :
https://www.cubcadet.com/webapp/wcs/...0-A/0020100014
I had that problem with my 149. It was next to impossible to find neutral. Replace the bushing and neutral is easy to find.
Project Uncle Dick
Cub Cadet 70
Old 12-13-2018, 04:46 PM
I will add that to the list of parts that need to sourced and ordered. Thanks.
Old 12-13-2018, 06:15 PM
There is an easy way to check: grab the damper plate and try to move is sideways while engine is running. If the speed changes the bushing may need replaced.
Project Uncle Dick
Cub Cadet 70
Old 12-13-2018, 09:06 PM
Thanks for the tip, I have not heard that before.
Old 12-13-2018, 10:41 PM
My 149 had the same problem you are having. I was able to move my damper plate side ways by grabbing the end towards the front of the tractor. The bushing was at least half gone when I fix it.
Double check the pin on the damper plate....it may have some wear.
Project Uncle Dick
Cub Cadet 70
