Old 12-13-2018, 11:28 PM
AndrewNoyes AndrewNoyes is offline
Default Convert QA-36 thrower to QA-36A
Hi,
Has anyone converted a qa-36 thrower to qa-36a? From what I’ve been able to see in photos and exploded parts diagrams, it looks like the primary difference is the quick attach yoke is adjustable on the A. My father in law gave me a qa-36, but I have a 1650 wide frame. I was thinking that it doesn’t look like it would be too bad to cut the yoke and make a plate, so that it basically is a qa-36a.
If anyone has done it, and has advice or prints, I would be glad for the help.
Thanks,
Andy
Old 12-13-2018, 11:36 PM
Yes, that can be done.
The difference between a standard and the "A" versions, is that the Quick Attach (QA) "A" version is adjustable for both NF and WF tractors.
You can cut, adapt, and weld up a standard version, and make it a permanent WF application with no problems.
I have seen it done before.
Old 12-13-2018, 11:56 PM
SLS327 SLS327 is offline
If you look up the attach for the qa36a in parts tree, one of the sponsors or ebay might have the yokes. Thats the only difference.
You could even buy the entire qa36a mule and bolt/repin the thrower to it.
Steven
__________________________________________
127 NF, spring assist, 36" IH Danco BB-36 snowthrower, 42" mower deck. CW-36 snowthrower, 42" NF blade. QA42A blower, 126,127,149,1720.
Old 12-14-2018, 07:40 AM
Thank you! If anyone had one apart and had dimensions for that plate, I'd appreciate a copy. Even a good straight on photo would be interesting.
Thanks,
Andy
Old 12-14-2018, 08:05 AM
There is NO instruction(s) on how to do this. It is all field fabricated to each designers/fabricator's mindset.
Then, one can always look for the proper front Bracket and not worry about the fabricating part.
Old 12-14-2018, 08:48 AM
Ok, thank you Roland.
