Hi All, I tried to drive the wheel bearings out from the other side with a hanner and old socket extension and neither would budge. Also they dont look like ball bearings or they are frozen. Are there some wheels that have bushings? Should prob just get a better set of wheels anyway but may learn something by posting.
Also, this axle is bent (wheel rim touches the axle at the top) can it be bent back? I have acetylene just not sure if that's kosher... Thanks for any thoughts... |
Likely just rusted in there real good. I use a large metal punch with a 3 lb maul l usually does the trick. You can attempt to bend the spindle back yes. But I would plan on replacing it sooner than later
No more cubs. But never fear there will be more ![]() ![]() ![]()
You make no mention of the model of tractor you are working on. With the exception of the Original, all other models had Ball Bearings.
As mentioned previous, knock them out. If you want, try some PB Blaster on the area prior, and let that penetrate a bit.
1964 Model 100. Which brings a question, were the wheel axle hole sizes the same for all narrow frames?
Your axle or wheel is bent? Looks like in the picture its your wheel. And if so, when you straighten it with heat those bearings will probably just about fall out.
![]() ![]() ![]() '76 1200 Dad bought '75 1200 "Twinsie" per my daughter |
I'm not sure , but it looks like the wheel might not be correct . maybe the offset is wrong. can you post pics. of both sides not so close to show the whole rim. and one straight on at the end of the bearing hole.
Looks like he thinks the knuckle is bent, not the axle.
The knuckles are supposed to be bent like that. How much if any on the example pictured is hard to tell w/o a hands on exam. I agree, the wheel looks suspicious, more like junk. He was lucky to get the wheel off the knuckle. I have several that are completely frozen, bearings wheel and all to the knuckles. Sad the way these fine little machines were used, abused, discarded and left to rot. |
It's definately the spindel, wheel has maybe 3/8" runout too when I turn it but at the farthest its still tilted in at the top almost touchin.
I guess time to search for some clean straight narrow front wheels (and could use one narrow rear), and a spindle. And a steering wheel shaft. And a hood that's not dented. And a real cub cadet choke control. Plus about 50 other parts! time for a parts tractor(s)? Is this how it starts? are wives usually cool with all this?
Model 100 Dec 2020 - Running condition, has snow plow! Model 123 Nov 2020 Hydro needs much work, or resto, building front end loader for this one Model 100 Feb 2019 apart for total frame-off / sandblast etc resto Model 70 Sep 2020 needs total resto and an engine, or for parts Model 70/100 Mar 2021 buried in rust, frozen engine, got free for parts. two spare hydro rears "in for a penny, in for a pound!" |
looks like the wrong rim or it's on inside out.]Is the other side that close as well?
Is the valve stem on the outside when you install the rim? |
| Thread Tools | |
| Display Modes | |
