Bent! Really gettin to know this tractor.
Look at the left vs right. I think someone dropped the tractor once. If I can find one cheap enough I'll buy it otherwise, it seems not too sloppy I will heat and bend it. Just may be hard to get it just exactly right... rather spend the $$ on some clean wheels anyway.
Model 100 Dec 2020 - Running condition, has snow plow! Model 123 Nov 2020 Hydro needs much work, or resto, building front end loader for this one Model 100 Feb 2019 apart for total frame-off / sandblast etc resto Model 70 Sep 2020 needs total resto and an engine, or for parts Model 70/100 Mar 2021 buried in rust, frozen engine, got free for parts. two spare hydro rears "in for a penny, in for a pound!" |
That is not a cub wheel. Here is one from a 70, look at the difference in the offset.
interesting, and weird. the left is ok (same style). the spindle is definately bent tho...
hmmm
This thing is the stop, it dosn't look so good either.
Your looks more like a wheelbarrow wheel. Does the other side, inside have the same offset?
yup they are same. the right spindle is bent upwards. the left side lines up straight to the eye. as to the spindle here's the free play video. tried to dial indicate it and that showed 40 or 50 thousanths at the top, more at the bottom... how much free play does it take to feel it? I could drill and sleeve that axle hole if needed but that's a lot of work.
https://youtu.be/hR3Byzfo1Ig the last pic is from a beutiful restored 100 that I found online .
Well if it were me, I'd bend it cold.
Spindles are normally case hardened to resist bearing area wear and toughen them. When you heat them you loose that. It got bent cold, so straighten it cold.
My front wheel looks similar on a newer machine,,,
The narrow wheel used on the 100, p/n IH-386188-r92, was used in a total of 31 applications, including trailers. FYI, here's the list....
https://www.cubcadet-parts-direct.co...vailable-Wheel |
| Thread Tools | |
| Display Modes | |
