Old 04-06-2019, 08:24 PM
sorner's Avatar
sorner sorner is offline
Default A 1250 followed me home
It is pretty complete, with side covers too. Pretty clean in around the engine and no rust on any surfaces. It was missing a coil and condenser, carburetor was half missing, and clogged fuel line. It came with a 44A deck all in good shape. I went into my spare parts and put all the necessary stuff on it and it cranks and tries to start. I see a little more smoke than I’d like to see puffing out the breather on the side. The carb is suspect, I borrowed it from the 1000 I picked up last weekend. I have 50/50 luck with cleaning gross carbs. This tractor is in overall good shape. It’s definitely going to be a keeper for me.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
IH Cub Original with deck
Old 04-06-2019, 08:27 PM
IHCubCadet147's Avatar
Good looking tractor!
Old 04-06-2019, 08:34 PM
twoton twoton is offline
That'll make a good mower!
Old 04-06-2019, 08:38 PM
Those crazy carbs with the funny choke lever, I had to static time mine to get it to start. Hope you git it to run, change the oil in before you start it.
Up to 534 and counting...
Old 04-06-2019, 09:38 PM
Good score on the 1250!
Old 04-06-2019, 10:53 PM
sorner's Avatar
If the engine needs an overhaul I have a standby K241AQS engine that would bolt right in. It has a .020 piston in it. Any issues with power since it’s a hydro if I put that in it temporarily? The 109 had hydro with a K241. It looks like those were pretty effective tractors.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 04-06-2019, 11:35 PM
Riley Henderson's Avatar
Riley Henderson Riley Henderson is offline
I don't see any problems putting a K241aqs in a 1250 does your 241 have the starter like the quietlines have or is it the starter generator setup. Might be kind of cool like a 1050 hydro QL it would be unique.
IH cub cadets 800x3,1000,1100,1200x2,1250DS,1450,1650DS, 71,122x2,123, 73x2,106,107,126x3,127,147x2,86x3,128,149, 169x2 ,Original, cadet 55, to name a few
CCC machines
1282,1050,2072,1535,1440
Old 04-07-2019, 06:57 AM
sorner's Avatar
It’s a QL K241, with gear starter. No starter generator. I have a k321 block too that needs bored. I might build that up to replace it and have 14hp. Or if it does ok with 10HP maybe I’ll just keep it. I’m going to change the oil first in the engine that’s in it to make sure it has 30 wt in it, just in case someone put too thin oil in it and that’s why it smokes. I doubt that’ll fix it but it’s worth a shot I guess.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 04-08-2019, 03:07 PM
sorner's Avatar
It was not the oil, it's a tired engine. I pulled it and dropped in the bored .020 over K241AQS so it's "temporarily" a 1050 QL. I got everything in and connected last night and went to bed at midnight. This evening I'll fire it up and play around with it. Maybe give it a bath and take some glamour pics.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 04-08-2019, 09:08 PM
sorner's Avatar
We have fire in the hole, it runs pretty good. I just need to tune the carb a little. It shakes quite a lot at midrange between idle and full throttle which I guess is normal. I'm going to look over the driveline to make sure that's buttoned up, and check the timing before putting it to work.
I forgot to mention, when I swapped the motor, there was only one bolt holding that K301 in... It has brand new looking iso mounts too.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
