Hi guys,
I believe I've heard that the standard Cub Cadet 3 point hitches can be made to fit the Super Cub tractors, so I figured I would ask the experts what's involved doing so. I picked a standard Cub Cadet 3 point hitch up from a nice member here on the forum. It's a model 389 (190-389-100) and it's from a newer tractor because it has the hole in it (and the "raise/lower" decal) for the adjustment rod for the mower deck. One of my Cubs, either the 2084 or 2182 will get the 3 point hitch installed on it. Has anyone done this? I believe it just needs some holes drilled in the 3 point assembly and a longer lift bar/rod. If anyone can help, it'd be very much appreciated. Here's the parts diagram for it: https://www.partstree.com/parts/cub-...ch-hydro-lift/ And here's a similar 3 point hitch that a company sells on ebay that fits both standard and Super Cubs. https://www.ebay.com/itm/Cub-Cadet-3...4383.l4275.c10 |
The 190-383-100 Cat 0 Hitch is recommended and will fit both the 2084 & 2182. The best I can see, the difference between 383 and 389, is that the 383 has the rear PTO provision and the 389 does not. Thus, if the rear PTO is of no interest to you, then the 389 should be OK to mount.
I'm not going to be using a rear PTO, so this 389 3 point should work just fine. I thought that the 3 point assembly needed some additional holes drilled in it to use on a Super Garden Tractor.
Any updates of your hitch?
| Thread Tools | |
| Display Modes | |
