I got it from one of my dad’s friends. It’s pretty beat up, but runs good. I’m going to fix it up and sell it.
Warning: The following images may be disturbing to some people. View at your own risk.
125, 126, 147, 129, 149 x 2, 1450, 882, 1810, 1320, 1440, 2135, 2 129’s for parts/project, 1950 Farmall Cub 38" LT mower deck, 4 42" triangle mower decks, 2 44A mower decks, 2 50C mower decks, 42” GT deck, 3 42" snow/dirt blades, 42" landscape rake, #4 cart ![]() ![]() ![]() ![]() ![]()
Those aren't bad mowers. Got family with a smaller one that does a great job. It uses just a touch of oil. Other than maintenance including a couple belts, the only repair I had to do to it is putting new brakes on the mower deck--crazy design, you think the deck is not running but the loose belt still makes it spin if the brakes are bad.
My friend has had a few come in the shop with a bent or broken drive pulley on the trans. They have a repair kit for that, $ and time. I watched that video the other day of a hydro-gear i think, where the shifter moves but the trans does not change. With just a little wear on the shift fork it slides over top of the gear it's supposed to move. Mike
Hey it's free and it's red, what is not to like about that?
When it is sold and profit is in hand, remember the kind gentleman that gave it to you with a small token of appreciation.
Since he wouldn’t take any money, I offered to help him with maintenance on his new tractor.
There are some of the Craftsman mowers that ARE good machines---within the realm of cheap mowers. There were some very cheap Cadets and Deere's built within the last 15 years. So far every part I have needed was in stock at a local independent mower shop.
It finally found a new home today. It went to another friend of my dad’s whose son just bought a house. I cleaned it up, changed the oil, replaced the throttle cable, and put a tube in one rear tire. I was also planning on painting the deck, changing the belts, and fixing some oil leaks, but he wanted it as is. Although it’s not a Cub, I will say it’s not a bad tractor. I’ve been mowing with it the past few weeks, it mows really nice and seems fairly well built.
| Thread Tools | |
| Display Modes | |
