I have a new to me 100 and finally got my deck installed today. The pto stays engaged all the time. Any ideas on what I need to check? Is it supposed to be engaged when it's touching the button or away from it? There aren't any markings on it.
Check the linkage on your PTO rod. You should have an adjustment on it that you may need to tighten, but before you do that, release it and inspect your carbon wear button that touches the PTO. If it is worn out, then you need to replace that first.
So it should be touching the button to be disengaged?
Yes, it should exert a small amount of pressure on it to disengage it. You will have to tinker a little with your linkage to find the point that will allow you to disengage the PTO, as your carbon button's wear will vary the setting of your linkage.
Ok thanks. I'll look at that first
| Thread Tools | |
| Display Modes | |
