Can you use a digital timing light with a tach to check the RPM on a K Series? If so, how?
125, 126, 147, 129, 149 x 2, 1450, 882, 1810, 1320, 1440, 2135, 2 129’s for parts/project, 1950 Farmall Cub 38" LT mower deck, 4 42" triangle mower decks, 2 44A mower decks, 2 50C mower decks, 42” GT deck, 3 42" snow/dirt blades, 42" landscape rake, #4 cart ![]() ![]() ![]() ![]() ![]()
Does anyone know?
I would assume that depends on the Manufacturer of the Digital Tach. I have seen some that check 8 - 6 - 4 cylinder engines only. You have to find ones that only do 1 cylinder engines.
I have used my old dwell meter set on 4 cyl. Take the reading 1k x 4 = 4000rpm. I use a couple Tiny Tacs also. Mike
The inductive pickup of the light clamps around only one spark plug wire, (the number one plug wire) and reads rpm from each time that plug fires. If you clamp it around the plug wire of your one lung Kohler, it won't know that it's not a Boss 429 Mustang.
Here's a manual..... https://csr.innova.com/Content/Manua...82582054484284 |
Thanks for the replies!
| Thread Tools | |
| Display Modes | |
