Old 05-21-2019, 03:00 PM
OK let's get back to the repair.
Old 05-21-2019, 04:35 PM
cooperino's Avatar
You know it Sam.. Just waitin on the parts.
Old 05-26-2019, 01:02 PM
cooperino's Avatar
UPDATE !
Okay, she is all back together again. It took a little more time than expected. Heres why.
As I said. Ordered new heads, coils, starter, seals, yadda yadda. I had also ordered a new kill wire assy. I installed everything, double checks clearances, air gap etc. The engine fired right up..ok great I thought. Well, still no power. First thing I thought of was "oh crap! Lew asked me about the cam" but I measured it and I had both cylinders the first time I put the new push rod in it. The pto ran and all. So, I started checking spark. Had good spark. I pulled plugs. Uh oh! One wet one dry. What could this be??? Pulled then engine again. Took off blower housing. Air gap still good. Not sure why I thought to do this but I pulled the kill wire and ohmed it out. One side "while connected to coils" showed open. The other side. Closed. Brand new kill wire from briggs with one defective diode. So anyway. I got her all back together. Fired up! BOTH CYLINDERS! YAY. So I cut the front grass hood still off just in case. Ran terrific. Lots of power. Very very happy!
PS, I should add. the thing that brought me to the kill wire was that when I shut off the key the tractor hesitated to shut down. The fuel solenoid is what was shutting it down. The kill wire had worked before all the work was done.
Old 05-26-2019, 06:58 PM
cooperino's Avatar
Just a comment about stamped rocker arms
Yeah,I get it George. Trust me, very familiar with stamped rockers. I was just sayin Briggs did this to go cheap. Also the prior design was nice because it had a piece between the 2 rockers that aided in adjusting. The new ones are separated so when you go to adjust them, they twist almost to the point that the rod can and has fallen out of the rocker. The old rocker type had much less twist.
In any event I did get them adjusted obviously and should be fine for many years. It was a fun project and I am happy with the results. Now that everything is running correctly the new to me 1641 will get much seat time as it will now be my go to cutter. This will give the 126 a break and it will be coming into the shop for refurbishment once the 100 is finished.
Old 05-26-2019, 08:35 PM
sorry coop, I shouldn't of derailed your repair post, It has been deleted.
Old 05-26-2019, 08:47 PM
cooperino's Avatar
No worries at all bud. Didnt bother me in the least
