I had to do some work on the 1772 the other day. In order to get what I needed done, it was easier to pull the front axle off. While doing that wasn't bad, I was surprised what appeared to be a washer-shim between the backside of the axle and the hanger for the axle and 2 washers that go on the pivot bolt just underneath the castle nut. I looked in the parts book and found no such parts, and then looked in the chassis manual and came up blank also. Has anyone taken a front axle off of their 1772 or possibly 1572 and found the same? Could this be a PO modification?
1989 - Cub Cadet 1772 1987 - Cub Cadet 1572 w/Rear PTO & Cat. 0 38" Lawn Sweeper #196483 42" L42 (Bush Hog) Rotary Cutter # 190349 45" 2-Stage Snowblower # 196364 48" Haban Rotortiller Rear PTO Driven #190356 54" SnowBlade with hydraulic Angle #196376 60" Haban Mowing Deck #196374 |
Probably a PO modification.
I've shimmed a number of front axles that way. Takes the play out by tightening up the axle in the frame pocket. Some just squeeze the frame.
Thanks Roland and Mike. This was the first time I've seen a setup like that.
| Thread Tools | |
| Display Modes | |
