I had about a full one quarter turn of the steering wheel before any response at the front wheels. I tightened up the bolts going through the steering knuckles and axle ends and it helped a little bit. I put in a Ross thrust bearing. I don't think that did anything at all. Has anyone done anything to improve steering on this model? I have not pulled off the wheel and shaft yet, but I am wondering if the cam follower has an adjustment that might help, or just replacing the cam follower. Also been looking for a tractor with one inch spindles (I saw a YouTube in which a guy used a front end from a 1872 to strengthen his front end). I have a loader on this so I understand the need to limit the load weight to avoid excess stress on the steering parts. Thanks for any help.
This should help you out. See link: Steering
Thank you ...that was VERY helpful....Mark
What a time getting the steering wheel off...I had to make my own contraption out of pieces of steel I had around to go under the wheel and then used a flywheel puller to get it off...had to leave it soaking in a combination of trans fluid with acetone, liquid wrench, wd40 and Kroil overnight
loose the WD.
it is a Water Dispersant, shouldn't have any water on the threads.
Roland has a bunch of years under his belt.... WD sucks in comparison to kroil, PB and a few others including the home made stuff "acetone and trans fulid" Ive seen a bunch of videos like this in the past. Wonder who really sponsors them ![]() Watch the video again.. You see him spray every product except for the WD.. Found that odd
Used to get that stinky Kroil in 5 gal pails, in my humble opinion, it's the
best out there. But when my source "dried" up, I switched to Peanut butter blaster. ![]() just something to ponder, found on the 'net https://lifehacker.com/when-should-i...-wd-40-5891936 |
[QUOTE=cooperino;486799] George been testing for about 90 years I think
Roland has a bunch of years under his belt.... WD sucks in comparison to kroil, PB and a few others including the home made stuff "acetone and trans fulid" I visited ol'George at the old Cubber's home recently and he said to tell you that he has been testing Kroil for 89 years...not 90...so there get yer facts straight ! Seriously, Kroil is the best but PB Blaster is cheaper.
Queen Of The Quietlines!
| Thread Tools | |
| Display Modes | |
