Old 09-06-2019, 07:55 PM
93Tim1440 93Tim1440 is offline
Default 2182 Super Cub with IH plow mounted, Identify ?
Hello, can anyone identify the model of this 48" IH blade mounted to the 2182 Super Cub? Important that I find out, your help is appreciated. Thanks.
Old 09-06-2019, 07:59 PM
Well I don't know what you have other than it is a PO mod. The 2182 should have a Haban plow.
Old 09-06-2019, 08:18 PM
I know it should have the 54", and I have no idea what a PO mod is. Wasn't looking for criticism if that's what that is. I was looking for identification help.
Old 09-06-2019, 08:31 PM
Looks like a Simplicity blade.
Up to 534 and counting...
Old 09-06-2019, 08:34 PM
SS5150's Avatar
SS5150 SS5150 is offline
Previous Owner modification......that's a plow that someone fabbed up themselves using an IH subframe. I see there's a pulley/ cable lift fabbed up too. Doesn't look bad really....you'll need to assess how durable/well built it is in person though.
RUN IN THE RED
1872 project
Cub Cadet Pro Z 560 L
Old 09-06-2019, 08:43 PM
It wasn't criticism, it was an observation.
To go along with what Sam stated, it is a NON OEM Dozer blade. Again, it looks like a custom fabrication, thus it is impossible to ID the thing.
Old 09-06-2019, 08:45 PM
I go to see it on Sunday, the owner says it works very well but the shoes are worn. If I don't learn what blade it is I will have to have some fabbed up for it if I buy it.
If I were to switch to the Haban blade, is there anything done to this that isn't reversible?
What would be needed along with the 54" blade, If I were to make it all correct?
Thanks all for your help.
Old 09-06-2019, 08:52 PM
I had no idea what PO was and you do run into wise asses on message boards from time to time. So I apologize for thinking the worst, but in my defense, the poster could have been clearer, I am not up on all your shorthand.
So if you will let it go, and give me a clean slate I will be more patient and ask before I assume something is bad in the future. Mea Culpa.
Old 09-06-2019, 09:12 PM
PO = Previous Owner
IF.....the blade is well fabricated, then there is no point in changing it out.
Old 09-06-2019, 09:39 PM
PO. Yes, SS5150 covered that for me in the post above. Thank you.
As far as if I decide to replace it. it will be a matter of how well it is done and personal satisfaction and desire. Won't be immediately if I decide to buy, but at a future date determined by funds and parts availability.
I just wanted to know what it would take to set it correct...
