I had to get a new voltage regulator And I cannot get this thing hooked up right on my new regulator there's an f post a battery post and L post any help would be great I have a yellow wire gray wire light blue wire
First, welcome to OCC............
![]() Did you buy a Cub Cadet V/R or aftermarket ...?? The "L" is NOT used on a 124. It is to be insulated so it can't short out.
It's aftermarket
And there is a post on back side of v/r
So if L is not used how where do the 3 wies go
And my 124 has lights
Look at the wiring diagram for your 124..... https://www.onlycubcadets.net/forum/showthread.php?t=35
Make sure you have an compatible aftermarket. You are using B (Battery), G (Generator) and F (Field). The regulator must be properly grounded.
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
I have my gray wire hooked to battery yellow wire hook to field and green or blue wire hook to back of voltage regulator
I think I shorted out my voltage regulator are these able to be fixed
First get it hooked up correctly . If memory serves, Gray wire is BATT, Yellow is Field. Blue is Gen.
| Thread Tools | |
| Display Modes | |
