Old 11-14-2019, 03:13 PM
chris hall's Avatar
chris hall chris hall is offline
Originally Posted by jaynjeep View Post
Nice!! Did you use a kit from SEW? or do your own conversion?
I used a SEW kit. It was cheaper for me this way. I think it turned pretty good.
105(sold)782x3 &124(sold) . Lawn sweeper yard cart. Homemade 3 point hitch narrow frame sleeve hitch spring assist ih snowplows . Rear weight bracket and suitcase weights.Lots of extra parts 😀.
Old 11-14-2019, 11:15 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
They do make nice kits!! Looks great.. i'm sure it runs nice!
Jay
Proud owner of the following:
Old 11-15-2019, 08:01 PM
chris hall's Avatar
It runs really good. Plenty of power and fairly quiet.
Old 11-15-2019, 08:52 PM
chris hall's Avatar
Default Working on the cubs
Got my 3 point hitch put back on my worker 782. Cleaned up my nicer 782 and swapped the mowing deck.[ATTACH]IMG_20191115_194346.jpg[/ATTACH]
Old 11-29-2019, 10:15 PM
sorner's Avatar
sorner sorner is offline
I tried to start up my 782 today with the snow blade on it to get ready for the snow/ice we have coming in on Sunday, and it took a while to start, which it never did... and then it stopped working all together. I smelled something get hot so I lifted the seat to look under there, I figured I melted the solenoid or something... NOPE. I melted the negative battery terminal. It looks like a solder drip in the bottom of the battery tray. I'm not sure what happened there, but now I need a new battery. I'm guessing it was an unclean connection that got real hot.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
IH Cub Original with deck
Old 12-01-2019, 12:44 AM
DownNdirt's Avatar
DownNdirt DownNdirt is offline
Tore apart my 1250 and discovered almost half of the cylinder wall is scored pretty seriously. Needs to go from .010 to .020 (maybe even .030 if they're bad enough. I'm gonna tear it down to bare block and see what a machine shop says about it. So much for using with my snowthrower this season.
'78 1250, '79 1450, '77 1000
Trapped and released: 124, 1000, 72, 1211
(JD) '70 140 H3 patio yellow, '74 140 H3, '87 332 diesel
Attachments: too much to list
Old 12-01-2019, 01:55 PM
Glued up a few new brake pads.
A 7.5" x 7.5" x 1/8" piece of friction mat'l from McMaster Carr will yield a dozen pads.
Old 12-10-2019, 06:14 PM
IHinIN IHinIN is offline
Not today, but Saturday I finished getting the 129 ready for winter. Swapped the ag tires for turfs and chains and added 217 lbs of weight. My homemade wheel weights are 50lbs each, IH weights are 26lbs each, and the weight bar on the hitch is 65lbs.
File Type: jpg AA165954-0B82-40D7-9717-5C10826924E1.jpg (28.4 KB, 99 views)
File Type: jpg 2A67B0C2-87D2-4DC2-94D4-0AC8005D4224.jpg (28.0 KB, 99 views)
File Type: jpg 0C454CBD-05AA-4A0E-B8C4-84CA649B0002.jpg (25.8 KB, 99 views)
Old 12-10-2019, 06:30 PM
john.knutson john.knutson is offline
What do you use to cut the material? I have never dealt with friction material but it seems like it would be rough on cutting edges.
Old 12-10-2019, 07:50 PM
Score it w/a drywall knife and it will break on the line.
The nip the corners off each piece with a side cutter.
