Old 11-18-2019, 11:50 AM
Stoltz80's Avatar
Stoltz80 Stoltz80 is offline
Default Qa42a/149 questions
Hey guys,
I just purchased a nice QA42A snow thrower for my 149. Does anyone know what length lift rod I need and also what length belt ? I know I can mount it all up and measure but I still have my deck on as I have many oak trees and a mow n vac that wont be removed for a few more weeks... I'd rather not have to mount and un-mount all that more than I must. Thanks for any help or direction
Old 11-18-2019, 12:22 PM
The drive belt for a 149 w/QA42A snowthrower is: IH-55053-C1 which 1/2" x 30"
Old 11-18-2019, 09:47 PM
Post 3 shows the adjustable lift rod I make
https://www.onlycubcadets.net/forum/...0target=_blank
Jeff
Old 11-25-2019, 07:42 PM
billfromwisconsin billfromwisconsin is offline
Default same question for me
I have the same snowblower, but on a 1650. It looks like the lift rod would be 1/2" round stock. I know from other ones they are bent on the ends. What is the center to center length of the rod? Any answers.....
Thanks for the help
Old 11-26-2019, 09:13 AM
Vrobert's Avatar
Vrobert Vrobert is offline
Default Rod length
I think you can use a chain with clevis links on each end. Once you have the length figured out you can swap it for a rod if you like
Rusty 149 project with:
QA42 snow thrower
38" deck
Barn fresh 1811 with:
44c mowing deck
QA42A snow thrower
42" snow blade
Old 11-26-2019, 03:54 PM
The rod on my 1450 w/QA42A thrower is 26.25" center to center
Old 11-26-2019, 06:43 PM
Default Thank You
Thank You....
Old 12-03-2019, 07:13 PM
KCabuzzi KCabuzzi is offline
Hi. Newcomer here. I have a 71 149 and I am wondering if one of these adjustable rods will give me the ability to raise my QA42 snowblower up a little higher. I have an issue coming out of my shed of the snowblower bottoming out before I'm completely off the ramp. Any help/advice will be much appreciated. Be gentle, I'm a rookie ! LOL !
Old 12-06-2019, 04:37 PM
mjs2011 mjs2011 is offline
I like that chain idea. It may allow the snowthrower to float a bit more on uneven ground.
I find myself setting down the snowthrower, then moving downhill, and as I crest the hill, I have to drop the snowthrower a bit more as its no longer touching the ground.
Old 12-08-2019, 08:34 PM
Mr Bob's Avatar
Mr Bob Mr Bob is offline
Default QA42 snow blower
Welcome to the forum KCbuzzi. Disconnect your lift rod and then lift the snow blower by hand. This will tell you how high it will go. Be sure your U joints are in alignment on the snow blower. The adjustable lift rod from Jeff works well. I have one on my 149 with a Qa36a snow blower. Have a great day.
Bob
