Ok. Took a minute but I see now. Thanks! I guess I'll need a measurement for the slot location too if it's not the same as it is on the curved links.
you make them a little longer than needed till you get your holes where you want them, as you can always cut them off. The thrower's front edge works best if it is at a right angle with the ground while supported. Also check chute clearance @ front of grill,both full left/right and allow extra as clearance does decrease due to hole clearances/slop and quick attach slop.
| Thread Tools | |
| Display Modes | |
