Old 12-15-2019, 11:58 AM
MikeMasheris's Avatar
MikeMasheris MikeMasheris is offline
You would need another splitter valve for 2nd cyl.
Old 12-15-2019, 02:57 PM
Red Dave Red Dave is offline
Yes, agreed. But the existing valves are part of the pump/reservoir/valves as a unit, no way to tap into a pressure line.
As far as I know, there is no other pressure outlet. But there are a couple other plugs in the unit's casting, I don't know if they are what I'd need or not.
Old 12-16-2019, 11:46 AM
You would have to run the lines from the pump to the a b valve then out of the valve to the cylinders can be done
