Old 12-21-2019, 03:13 PM
Nato527 Nato527 is offline
Putting some of the pieces back together today. I bought PPG paint this time. The last couple of times I bought Nason. The PPG paint went on waaaay better. The thing is the two Federal Yellow colors are definitely not the same shade. Guess I'll just park them away from each other....
Nate
Old 12-21-2019, 03:18 PM
Question on the hydro suction tube. When I got this tractor it had this on it for a suction tube. Drove fine, mowed fine, no leaks. It's not the factory one, but I'm wondering if I should replace. Why is the factory one so long?
Nate
Old 12-21-2019, 10:39 PM
IHCubCadet147's Avatar
It looks good!
Old 12-22-2019, 09:36 PM
Finally starting to look like a tractor.
Nate
Old 12-23-2019, 01:11 AM
guido guido is offline
Looking god Nato.
I especially like how you trained that grill casting to "hang ten". Surfs Up!
Alan
Basket Cases: 129, 1450 sold, 1650
125: 48" Mower Deck, Windbreaker Cab
127: 3 turn steering gear, Spring Assist, Sleeve Hitch, 48" Mower Deck, Dozer Blade
147: 3 turn steering gear, Spring Assist, QA36a w/Xtreme Motorworks Wings
Old 12-23-2019, 08:07 AM
SGragg SGragg is offline
Inactive Member
Looking good! Thanks for keeping us in the loop.
What kind of painting mask/breathing apparatus do you use? I'm assuming with the PPG paint, you're using hardener.
Stanton
1980 IH 782, Kohler M18
IH #1 Cart, original
2015 XT2, Kawasaki 23 HP
Old 12-23-2019, 05:46 PM
This is what I use. I believe they call this a charcoal filter. I use it with a pre filter. ( not pictured) . I love the full face respirator, it doesn’t hurt my nose like the half face respirators. Ive been painting as a hobby for about three years now. Totally self taught, and I’ve made every mistake I think a person can. Including thinking a blue bandana would be a “good enough respirator”.....the activator /hardener used for single stage paint is bad,bad stuff. Good ventilation,covering as much of exposed skin as possible and leaving your respirator on at all times is a must. Just my 2 cents. I’m sure there’s other people on this forum that know waaaay more than me about painting.
File Type: jpg F907A876-45D6-4C0D-9C18-3BBD2D269624.jpg (20.4 KB, 106 views)
File Type: jpg 8978584A-F0D8-4723-9B5B-F6E86C34E0AF.jpg (23.1 KB, 107 views)
Nate
Old 01-10-2020, 07:46 PM
Hopefully finishing up the rest of the yellow tomorrow.
Nate
Old 01-10-2020, 09:04 PM
Cooling!!
Put fins on the line like a 2 stage air compressor, and it will really cool.
Do we need it? that's a big debatable subject.
----Depends on what one is doing with the tractor.
Old 01-11-2020, 08:38 AM
Cooling!!
Finally an answer, thank you ol’George. That makes sense now that I think about it. The longer tube allows fluid to cool before it makes its return trip. Not sure what the duties of the 105 will be, probably just a run around tractor. Pulling a trailer, disc , plow. Keeping the 125 on mowing duty.
Nate
