Old 02-27-2020, 08:05 PM
john hall's Avatar
Default Hydro adjust
On my 2284 the only way I can get reasonable reverse speed is to adjust cam pivot bracket way low. Service bulletin says flush with top of washer over the slot. It was already lower and would barely back up sometimes. After adjusting to get decent speed I adjusted connecting rod to neutral of rear and the dash. Now it has full forward speed with lever 2/3 the way up. Linkages and pins look great. The trunion looks too good. No wear as in maybe replaced? I went ahead and changed springs and buttons. Also 1 ball joint appears replaced. Any ideas as to
the odd adjustment or just run as is?
File Type: jpg 2335AF9B-E393-49AD-98E0-60DB89A16F32.jpg (24.7 KB, 200 views)
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 02-27-2020, 08:29 PM
john hall's Avatar
Also there are 2 holes for the linkage, which one is correct?
File Type: jpg ABC75AE9-7D6A-4C0D-85D7-104C7C45BB78.jpg (22.1 KB, 195 views)
2072 w/60" Haban
Old 02-27-2020, 09:23 PM
I would move it to the top hole in the cam plate, see if it makes a difference.
Up to 534 and counting...
Old 02-27-2020, 09:41 PM
john hall's Avatar
Thinking the same thing. It's cold by Southern standards and I had the heat on, so no raising the door up to run it tonight so I could re adjust.
So I spent the evening trying to get the right hand brake pedal unstuck--its still stuck. Wish I would have seen this before I put the fuel tank back in. Hot wrench would have helped.
2072 w/60" Haban
Old 02-28-2020, 05:13 AM
guido guido is offline
Did I read you correctly that you stated that one of the ball joints appeared to have been replaced?
Just a thought... Is it possible that the connecting rod needs some adjustment?
Alan
Basket Cases: 129, 1450 sold, 1650
125: 48" Mower Deck, Windbreaker Cab
127: 3 turn steering gear, Spring Assist, Sleeve Hitch, 48" Mower Deck, Dozer Blade
147: 3 turn steering gear, Spring Assist, QA36a w/Xtreme Motorworks Wings
Old 02-28-2020, 07:16 AM
I was thinking along the same lines, but with the entire linkage.
Old 02-28-2020, 12:26 PM
john hall's Avatar
I adjusted that as well. Going to start fresh by moving the connecting rod to the other hole and see if that improves things. As it is I get full travel in forward but still not in reverse. Given some of the other things I have found on this machine, it may have been bolted together wrong at some point.
2072 w/60" Haban
Old 02-28-2020, 08:48 PM
John, you're a member of Cub Cyclops. In the files section is a service bulletin about slow reverse on the Cyclops. The bulletin was provided to me by Lew.
Old 02-29-2020, 07:44 AM
ironman's Avatar
ironman ironman is offline
John, you're a member of Cub Cyclops..........:
Sounds intriguing, do you guys have some sort of secret handshake or greeting phrase??
Old 02-29-2020, 09:55 AM
Yep.
https://www.facebook.com/groups/666265203510023/
