Old 03-19-2020, 05:52 PM
three4rd three4rd is offline
Default How are Stens air filters?
Need to do the yearly replacement on my 129. I came across a Stens filter - cheap enough at around $5, but was just wondering if it's any good? On the cub parts website the part # for the filter is IH-385168-R3. They go for around $19. Other Cub websites also charge close to that. One outfit has a filter that looks like the right one for around $9. The only difference in the part # is R2 at the end. No idea what the 2 or 3 designations refer to (?) I imagine there are good number of filters that effectively cross-reference for the above IH number. As long as it has the proper shape that fits against the base, it should work. Any suggestions?
Also...in looking up these things on the Cub website, it refers to a round "air cleaner seal" - KH-237423. What is this? If there is supposed to be something between the base and the filter, I've never had it. Also interesting is that the air cleaner cover, as pictured, has a tube coming out of it on the top, then a clamp, and then a hose (IH-229453-R1).
I'm finding all this under the model 129 assemblies and so am confused as to what 129 tractors might use something like this? Are these parts listed by mistake somehow and perhaps apply to models other than 129?
Old 03-19-2020, 06:14 PM
The correct Cub Cadet Air Filter for the 129 is IH-385168-R2 ------> IH-385168-R3
The correct Kohler Air Filter is: 235116 -------> 25-883-03-S1
You can order these part numbers or use them as Cross Reference.
Old 03-19-2020, 07:22 PM
Thanks Roland. The Sten would fit....just not sure how good they are. I found one that cross references to the Kohler number you provided - as well as the IH number, so it's definitely the right one.
Old 03-19-2020, 07:32 PM
My experience with stens products/parts is they are oem quality.
I've not had a problem with the parts I've used, and never hesitate to use them.
I'd say a good aftermarket choice.
Old 03-19-2020, 10:53 PM
X2 I have used their air filters and belts on my cubs with fine results. Great alternative.
Old 03-20-2020, 09:50 PM
Riley Henderson's Avatar
Riley Henderson Riley Henderson is offline
X3 here I use stens products as well with positive results, and they are cheap enough to replace when in questionable condition.
IH cub cadets 800x3,1000,1100,1200x2,1250DS,1450,1650DS, 71,122x2,123, 73x2,106,107,126x3,127,147x2,86x3,128,149, 169x2 ,Original, cadet 55, to name a few
CCC machines
1282,1050,2072,1535,1440
Old 03-25-2020, 01:26 PM
Thanks guys...turns out the one I decided on buying came in Kohler packaging, so assuming that's what it is. But, now I know for next time.:
