Old 04-15-2020, 06:56 AM
Another cover that has not seen the light of day since it left the factory.
Old 04-15-2020, 08:02 AM
Billy-O's Avatar
Billy-O Billy-O is offline
Taking a look where the sun doesn't shine
Plow blade
#2 Cart
QA36 snowthower
Old 04-15-2020, 09:36 AM
That gunk coating the inside of the gearcase and cover is the result of the Hy-Tran doing it's job encapsulating the moisture. That's the treason for using it in the 1st place
\Make sure you get it all out, don't want a lump of that crap getting sucked into your new filter.
BTW, you did get the correct filter or equivalent to a Cub Cadet 723-3014 I hope???
Old 04-15-2020, 01:46 PM
fried fried is offline
Originally Posted by mortten View Post
Watch putting the cover back on. The bottom 3 bolts are longer. You can crack the housing putting the longer ones on top.
I did notice that those three were longer. Has anyone had problems with those three bolts holding up when using a plow on a sleeve hitch?
I plan on using a toothbrush or nylon scrub brush to scrub the solids with Solvent, Kerosene, or Diesel to help loosen it up.
The filter I ordered was WIX 51410. It says that it's a hydraulic filter. If this won't work, let me know so I can order the right one.
Bringing light to where the sun don't shine!
Cub Cadet 149
Cub Cadet 126
Yanmar YM2500
Old 04-15-2020, 09:20 PM
I was able to get all of the sludge cleaned out today. I used a wire brush, some PSC1000 and brake parts cleaner. Now I'm waiting on gasket/filter/hytran.
Cub Cadet 149
Cub Cadet 126
Yanmar YM2500
Old 04-16-2020, 09:35 AM
mortten mortten is offline
There is a debate on the 51410 filter. The Cub part number crosses to that number. But if you look up on the Wix website it lists a 51084. The filters are the same except the 51084 has an anti drain valve. So the question would be does the Cub filter have an anti drain valve in it? If it does it hen the 51084 would be correct. If it doesn’t then the 51410 would be correct. I don’t know the answer. If it were me I’d go with application rather than crossover.
Doug
QA-36A
42" blade
Old 04-16-2020, 10:06 AM
I would like to hear more about the debate on the filters. I remember reading somewhere that you want to use a filter without the anti drainback valve for full flowing hydraulics but I can't remember where I read it. I pulled the information on this snip image directly from the Wix website to compare the two filters.
Cub Cadet 149
Cub Cadet 126
Yanmar YM2500
Old 04-16-2020, 11:08 AM
My understanding of the anti-drain back valve is that when a filter is positioned is a position other than vertical it prevents the filter from draining and causing a dry startup. The filter on the Cub is horizontal and without actually measuring, it appears the top level of the reservoir is slightly below mid level of the filter.
Doug
QA-36A
42" blade
Old 04-17-2020, 08:08 AM
Smile
Ok. With that on the table i'm going to continue with my initial hydraulic filter I selected.
Got the filter installed last night. My rear end gasket should arrive today then I can button everything up. I was planning on doing the first test drive today but the stripped out spark plug hole had other plans for me. I'm waiting on a ebay pull off head to come in also.
Cub Cadet 149
Cub Cadet 126
Yanmar YM2500
Old 04-17-2020, 09:24 AM
The Wix 51410 is the correct replacement for the Cub Cadet filter.
Tags
149
