Old 06-04-2020, 08:48 PM
dino062959 dino062959 is offline
Default Ignition switch
bought a 1641 2weeks ago ignition switch keeps going out.no dash lights replaced switch and that went three days later what can i check to see why
Old 06-05-2020, 07:10 AM
OK, can you clarify your posting in plain English. It is hard to understand what you want. !!!
Old 06-05-2020, 11:52 PM
i need to know why the ingintion switch burns out after a few days
Old 06-06-2020, 03:45 AM
cooperino's Avatar
1. Its wired wrong.
2. Wrong switch
3. Short in wiring
4. High amperage draw
Those are the only 4 things i can think of that would burn that switch up.
There is no one specific answer to your question because you have not given enough information.
Your going to need a wiring diagram and a meter. Then we can help you diagnose it.
Old 06-06-2020, 06:47 AM
The correct Ignition Switch for the 1641 is: 925-3163
Old 06-06-2020, 07:44 AM
It would also be helpful that you explain "burned up"
---Did you take it apart and see melted contacts inside?
--- Was it hot and smoking?
---Were the terminals melted off on the outside?
----or did it just quit working.
I think you see where we are coming from.
In order to help we need facts and history or pictures in some instances.
Calling the doctor and saying I'm not feeling good is not going to get much results,but if you added, yesterday I fell out of a pee cup truck on the highway we would get a better idea of your problem.
Old 06-06-2020, 08:23 AM
switch just quit working was running fine.i was mowing and then machine just quit running like some thing shut power off at switch
Old 06-06-2020, 09:28 AM
What.....???
Old 06-06-2020, 10:59 AM
Sounds like it just plum quit.
It could be out of gas,
or engine done blowed up
bat tree could of come unconnected
wire could of come off something
fuse could of blowed.
some silly safety switch could of malfunctioned
could have ignition system problems
fuel flow could of stopped to engine.
could of run over a brick or neighbors bowling ball
Time to determine which system stopped it.
Electrical?
fuel?
Air?
Mechanical?
If you don't understand simple diagnostics, you might consider taking it to a repair facility.
I can't remember where I last put my tell all Crystal ball, so I can't do
tela-pathetic mechanic, like them sitty doctors are now doing because of the china virus
Old 06-06-2020, 11:01 AM
cooperino's Avatar
Electrical?
fuel?
Air?
Mechanical?
You forgot loose nut behind the wheel and the muffler bearings.. Could be anything at this point.
