I will attempt to address my procrastination problem while you wait.
This is my first post, so I hope I get it close to correct. I just recently started restoring some attachments for two 782s my uncle got in the early 80s. Both still run and one we even still use to till our garden. The attachments were a Brinly plow and the deck. They were both practice items as I’m planning to re-do one of 782s next. Fingers crossed they’re some pics in this response...
What processes did you use, and would you do anything differently?
I.E. your methods to strip, prep, and paint those rusty attachments.
Rusty 149 project with: QA42 snow thrower 38" deck Barn fresh 1811 with: 44c mowing deck QA42A snow thrower 42" snow blade |
It is amazing what a bit of polish and elbow grease can achieve
Oz
My wife says I do not listen , at least I think thats what she said |
I took everything apart that I could get apart. I used penetrating fluid, an impact wrench, and a torch (for heat, not cutting). On the plow I started removing paint/rust with a braided wire wheel on an angle grinder. In the hard to reach places I used a wire brush on my drill and for the really tight spots a dremel with wire brush like attachments. Then I sanded some places by hand. I cleaned up all the dirt, dust, etc and primed with Rustoleum rusty metal primer then painted. Afterwards I reassembled and touched up some places.
For the deck, I used a random orbital sander to remove the rust and flaky paint. The metal on the deck is so much thinner than on the plow and I didn’t want to scar it with the wire wheel. I sanded quite a bit moving from course to fine grit. Then I followed the same prime and paint process. The deck also required the use of a ton of degreaser. In 40 years the amount of grease that accumulated was incredible. There are a few things I’d have done differently along the way, but that’s mainly to save some skin on my knuckles. I’m sure someone with more experience could show me some ways to do things better, but I don’t know what they are. I went ahead and replaced the spindles while I had it apart. I’m an accountant by trade, so figuring those out was a little tricky for me. Also I painted everything with rattle cans. They worked well for the attachments, but I’m planning to uses a spray gun when I start painting tractor parts. |
I just checked a 50 that I have out back and there is no bend.
No bend in the 44 either.
| Thread Tools | |
| Display Modes | |
