Old 07-13-2020, 09:22 AM
Herndog Herndog is offline
Default Engine starts, running poorly after 30 minutes
I have a Cub Cadet 1250 with a recently rebuilt Kohler 301 engine. The engine runs fine for about 30-35 minutes, then starts running poorly with such a loss in power that I just have to shut it down in the middle of mowing our yard. After about 45 minutes of a cool down I start it back up and finish the yard. I have replaced the ignition coil thinking it was getting hot and then causing spark issues, but the problem still exists. (I have also replaced the spark plug as well.) I do not think it is a fuel problem since this scenario has repeated itself several times: run great for 30 minutes, then runs terribly. Any ideas about what to try next?
Old 07-13-2020, 09:40 AM
Wouldn't rule out the fuel supply issue. All it takes is a piece of crud getting
sucked up in your fuel inlet to shut you down. When everything settles down
after it sits for a while it fires up and off you go. Till it gets sucked up
again. Eliminate all chances of a junk in your fuel tank which takes time
and not much for money, ( maybe some new fuel line) and that variable
is no longer there. Worth the effort every time.
Ken
Old 07-13-2020, 10:05 AM
First, welcome to OCC..........
Would this be the correct Kohler Coil or an aftermarket one ??
Old 07-13-2020, 11:57 AM
Condenser may also act that way
Old 07-14-2020, 02:00 AM
Ozcub's Avatar
Ozcub Ozcub is offline
Fuel vacuum could be the problem , make sure the tank is venting
Oz
Old 07-14-2020, 08:14 AM
Billy-O's Avatar
Billy-O Billy-O is offline
Some good ideas and I'd like to add..... too hot! Look under the tins between the fins for things blocking the winds.
Plow blade
#2 Cart
QA36 snowthower
Old 07-14-2020, 09:08 AM
Check this for blockage.
https://www.partstree.com/parts/cub-cadet-ih-109042-c1/
Old 07-14-2020, 12:09 PM
Hairtrigger's Avatar
Hairtrigger Hairtrigger is offline
On one of mine I had to run an appropriate sized drill bit using my fingers to get the crud out of the inside
did not need to replace mine
Tags
loss of power, problems after 30 minutes
