Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines > Briggs & Stratton Engines
Old 07-23-2020, 07:29 PM
Getter-Done's Avatar
Getter-Done Getter-Done is offline
Default Smoking 16hp
Hello
New member here.
I'm working on my 1641 in this range of serial # below.
{1641 (145-653-100) - Cub Cadet Garden Tractor (SN: 821060 - 880000) }
When I started It this evening it was really smoking.
Where is the best place to buy parts/ Rebuild kit ?
Thanks in advance for your help.
Model #303447 Type 0447-01 Code 940916
Old 07-23-2020, 07:55 PM
I would suggest you take an aspirin and maybe a short nap.
I have owned several 16 hp Vanguards that smoked and none of them required a rebuild. Might be best for you to figure out what is causing the smoke and report back before all the jingle runs out of your pockets?
Old 07-23-2020, 08:18 PM
Thanks.
I will take that advice.
When I purchased it a few weeks ago it was fine.
It is (freshly rebuilt) was the story.
It sounds great.
I will pull the plugs and take a look.
Also Run a compression check.
I will take the muffler off. and check things out .
I will post a picture of the muffler.
It does not look like it is burning good on both cylinders.
Thanks
Old 07-23-2020, 09:04 PM
I run compression test.
150psi even both sides.
Right Plug looks normal,
Left Plug Wet. Gas/Oil.
So spark check.
Right side
Left side
I will look when it gets dark.
I think it has not had spark on this side for a while.
Here is a picture of the Muffler.
Old 07-23-2020, 09:45 PM
Update.
No spark on left side.
Old 07-24-2020, 11:09 PM
Update.
The coils check the same Ohm resistance .
The flywheel is rusty.
I will clean this.
I am going to check the gap.
Does anyone have that info?
Old 07-25-2020, 05:25 AM
Cannon51's Avatar
Cannon51 Cannon51 is offline
The kill wire that attaches to the coils has diodes in it. I've read that if they go bad it can cause spark failure. I had to replace the one on my 1641 because it got pinched in the shroud.
Cannon
Old 07-25-2020, 06:20 AM
Cannon
Thank You.
I will check that.
Old 07-25-2020, 07:28 AM
Originally Posted by Getter-Done View Post
Thank You.
I will check that.
The armature air gap is .008-.012.
If you can spin the engine, just remove the kill wire from both armatures and see of both of them spark.
I just replaced a kill wire because of an open diode and one side wouldn't fire.
Some multimeters can check diode function.
Old 07-25-2020, 07:42 PM
I want to Thank both of You.
Mike McKown for slowing me down .
And Cannon51 for telling me about the wire.
And Mike for instruction of leaving the wire off
It was that wire.
I swapped the coil side to side
Tested everything.
Blah Blah
Then left the wire off and (Bam)
Here's a picture
So 2 more Questions.
#1: Where is the best place to buy this wire?
Also there was nothing hooked to it on the outside of the engine.
#2: Does it have to be hooked in the wiring?
