The CV joint is about 2-3/4" OD. Get a set of braces on that 882 before you bust something.
When i got mine they had just rebuilt the front joint all new and didnt do rear end. So i have half a new shaft... reaar is shot and almost ruined the hydro so i got a cv setup to replace it
982D kwik-way loader w/3 spool control and front and rear remotes,2182, 1812 cat 0, 1440 puller, 3185 grass killer, 2x 450s, QA42, 364, tiller |
Josh Diesel Cub Cadets........... |
I have been running the cv drive shaft in my 782D for three weeks now
Nice set up but expensive. No problem with clearance. Got the adapters from Mac. Found a drive shaft from an 1863. Including the fan. New boots and seals for the cv's. Cut and sleeved the shaft to shorten it. Will not say it is great till a few hundred hours. Seems smoother even with the single coiled pin style shaft for the hydro pump. Would prefer to have used the spline shaft for the trans end. Still working on removing the four tight bolts in the axle flange's to install the axle braces Joe |
Hi Joe, don't you just love locktight on steel bolts in aluminum? Makes you feel all warm and fuzzy. Even though you know the worst thing world is a strong mechanic. Mike
When you get a chance could you post some pics of what you did to shorten the shaft?
Really like the CV drive shaft in the 782D
If I had looked closer the alt belt would have been changed. Only two years old. Sam Mac did a great job on the adapter's |
Looks good Joe!
Something that is on my 2084 and our 2072 is a piece of rubber wrapped around one of the hydro lines to keep them from vibrating against each other. A 1 inch piece of garden hose and a zip tie would work.
With my son, EricR Super 2084 with 54" mower, 451 blower. 2086 with 3 pt hitch, 54 inch deck, 551 blower, 54 in brinly blade. A 4 digit original w deck. A 70 with deck. 2 102s both with 42 in decks, one with creeper, 1 36 inch IH snow thrower CW36, 1 42 inch IH blade. 149 with mower. 2072 w 3 pt hitch, Johnny bucket, 60 in mower, 451 blower. Jacobson GT 10 with mower. DR Lawn vac tow behind,Home made lawn roller. Brinly cart, 2 off brand carts and 1 home made cart. |
Having a similar issue and need to replace my driveline flange (703-1005A)in a 882. The link someone provided above for the replacement Bushing by itself is no longer working. Does anyone have any specs on that bushing?
| Thread Tools | |
| Display Modes | |
