#21
thanks guy thats *very good* info. so u say u ran the loader off the ported hydro, but you also had power steering? or did u mean that the loader cutting out?
any video of the loader with the hydro pump? anyway I like the idea to run a pump off the back side of the hydro pump like in the link that twoton posted (mostly because I'd have to find and buy a ported hydro anyway) https://www.onlycubcadets.net/forum/...807#post288807 . Quote:
Model 100 Dec 2020 - Running condition, has snow plow! Model 123 Nov 2020 Hydro needs much work, or resto, building front end loader for this one Model 100 Feb 2019 apart for total frame-off / sandblast etc resto Model 70 Sep 2020 needs total resto and an engine, or for parts Model 70/100 Mar 2021 buried in rust, frozen engine, got free for parts. two spare hydro rears "in for a penny, in for a pound!" |
#22
2084's come with PS
loader always worked fine the PS would fade with the bucket up about middle of the range. I always thought it needed more fluid than the rear could hold. I think this is the only known video of it in action, Son is running it https://www.facebook.com/10001298401...7245758384885/
JD x475 |
#23
thanks guy...
the video said "This Content Isn't Available Right Now" would love to see it tho thanks for the info on the PS. I agree and a supplemental reservoir may have helped perhaps...
#24
I think you'll want a joystick type valve, as most loaders come with a single lever control. Here is a twin spool, open center, with float valve.
The advantage of a joystick valve is you can lift/lower and curl the bucket at the same time. You'll want to be able to do that. https://www.surpluscenter.com/Brands...57-9-12475.axd
Here's an easy way to mount a hydraulic pump without using your PTO. It is mounted behind the hydro and driven by the hydro's rear input (output) shaft. The pump is inexpensive, and the mounting process is not expensive if you have the fab skills.
I can't take credit for the idea, somebody else posted this method, I just copied it. This is my tandem and the pump drives the hydraulic dump bed cylinder. The tractor did not have a ported hydro.
sawdust thats some cool stuff you have!
#27
Sawdust,
Can you provide details on the pump in the picture? |
#28
He has a thread on the build of the tandem pictured, you can probably find the specifics there....
https://www.onlycubcadets.net/forum/...ad.php?t=50847 |
#29
Thanks Ironman!
#30
this was also shared a few posts back. same clever rear pump setup, great pictures of it
| Thread Tools | |
| Display Modes | |
