#41
Nice score on the NOS!
#42
Thank you also got 4 implements for 250$
#43
Ok guys today's the big day gonna finish asseby of the engine and try to start it. I put in the steel governor gear and the billet connecting rod with bearing had to order a standard bearing for this connecting rod. I timed the balance gears and cam shaft and used assembly grease. I also got a zinc additive to add to the 30w oil to help everything properly seat. I'm going to temporarily mount the engine on my old frame to test it and let it break-in some. I also used my K241s flywheel bearing plate and blower housing. I hope all goes well wish me luck
#44
Well she's alive fires right up just gotta get that darn govnor spring adjusted right. I've just got it rigged up to run on my old frame. It's runs smoothly then that spring gets out of adjustment then revs high n I have to shut t it down or hold the throttle lever back.
#45
Well I figured out the governor issue I need a throttle return spring there's a place for one but can't find a part number to locate one.
#46
It was my understanding that the 6.00-12's are taller than the 6-12's.
Not a big deal as long as you are not putting them on a 4 wheel drive tractor. HTH
The Cub Pack. 70, 100 (creeper), 104, 122 (2), 1250, 1810, 1863, 2182, LTX 1050, SLTX 1050, SLT 1550, SLT 1554, Snow Chuckers 450, 451, 826T, 1030E, 2 plow blades. always looking for "just one more"
#48
Also available at Amazon, same price.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 I put them on this 70. |
#49
By any chance, will 6.00-12 chains fit 6-12s?
#50
X2
that's were I got a set from last week for my 104.
| Thread Tools | |
| Display Modes | |
