Old 03-04-2021, 10:08 PM
sawdustdad's Avatar
I think the answer is a pair of new auto relief valves that both failed at about the same time. Less than a year old.
Old 03-04-2021, 10:14 PM
Cubcadet_107's Avatar
Well that's unfortunate, and confusing!
Not entirely sure what would ever cause a set of almost new relief valves to fail so quickly.
'70 107 with k301 engine swap
'71 106 with 38" deck
'63 70 "pinkie"
1863 with 54" deck
105 x2 (parts)
Old 03-05-2021, 07:05 PM
sawdustdad's Avatar
Yes, concerning. I bought 4 "new" auto relief valves from MachTechDirect.
I tested them again today. I have a working hydro attached to a rear end on a wood cradle. The two relief valves in it were working. I ran the hydro with a drill and verified axles rotated as expected when the trunnion arm is moved.
I replaced one valve with one of the suspected failures (reverse side). Reverse no longer worked. Swapped the two valves. Forward no longer worked. Installed the second suspect valve. Neither direction worked. Replaced original valves, both directions worked.
So both auto relief valves are faulty.
Go figure.
Old 03-10-2021, 07:53 AM
Go figure.
go figger?----
Me figures maybe you are not getting "the real picture" with the slow rpms of a drill motor.
Try them in an actual Gt operating under normal circumstances.
Just trying to think out of the box.
Old 03-10-2021, 08:01 PM
sawdustdad's Avatar
go figger?----
All the other valves work with a drill driving them...
