Is there as good source for finding the hydraulic angling kit for a 3000 series plow? Just yesterday, I missed out on a local deal to purchase a complete tractor with a busted rear diff for $600
It had the angling kit
Did you try our Sponsors, Patton and/or Houtz, as listed at the top of the page ?
What all is required to convert from a manual to a hydraulic angling kit? Is the plow bracket the same? I'm assuming I need lines, valves, and the handle as well. I ask because a gentleman has the cylinder for sale, but also has the bracket with it. I assumed that would be the same.
You can use an existing front hitch with manual angle. You will also need the angling cylinder which is different than the lift cylinder along with what you mentioned. Be sure when buying a cylinder it is an angling cylinder and not a lift cylinder because the strokes are different.
The "bracket pictured above" is called a front hitch. Based on your first post you already have a front hitch with manual angle so you just need the parts to convert it to hydraulic angle.
I'm finding out that this is a very costly endeavor, lol. This tractor is going to be dedicate to pushing snow. Is there any reason I couldn't re-route the hydraulic lines from the deck lift to the angling cylinder?
how about this?? Grand rapids Michigan Craigs list. It's not quite what you need, but thought i would pass it along in case it was helpful.
https://grandrapids.craigslist.org/g...271224945.html
Mark from Minnesota 3165 with CC Snow Blower, Front blade, Sims Cab 3185 with 3pt hitch, it runs now. But not well. 48in and 52in mower decks 2185 with mower from my dad when I have a project for it. Massey Ferguson Model 70 corn planter. CC yard cart |
If you don't want to mow lawn anymore re-purposing the deck lift is a good option. You may be able to use the same cylinder and extend the hoses. The deck cylinders have an elongated hole on one side. You will most likely need to fill that solid some how.
| Thread Tools | |
| Display Modes | |
