Old 03-29-2021, 03:21 PM
Andrew Andrew is offline
Default 1975 Cub cadet 1200
If starter is rotating backwards it won't engage the engine won't turn. My starter has 12 volts to it but does nothing not even a click. I bench tester starter and it rotates backwards.
Old 03-29-2021, 03:44 PM
First, welcome to OCC..........
The 1200 rolled out of the factory with a Kohler K301AQS-47622 engine. On that engine should be starter:
Kohler: 45-098-06 -------> Repl:45-098-11
Bosch: 14925-27-M030SM or
Bosch: SMH12A201
13 tooth. CCW Rotation. Used on Kohler K241, K301, K321, K341. 10 thru 16 hp Engines. Direct replacement for OEM. Replaces KOHLER 45 098 06 / 45 098 11
You should be able to check & see the "stampings" on the starter to see if you have the right one.
Old 03-29-2021, 07:13 PM
It is suppose to turn when looking at the end of the starter gear ccw.
Old 03-29-2021, 07:35 PM
Bryan S Bryan S is offline
I was almost positive that they spun CC as Lew mentioned.
I remember reading that many times on the forum.
So to try and help solve your issue, I went out to the 1250 I bought last week and turned the key. Yes as Lew said,
it does turn CC if you are looking at the starter end that has the gear which turns the motor over.
Check your wires, at the battery, ground wire to frame, everything needs to be clean. HTH
EDIT: CC = Counter Clockwise
The Cub Pack. 70, 100 (creeper), 104, 122 (2), 1250, 1810, 1863, 2182, LTX 1050, SLTX 1050, SLT 1550, SLT 1554, Snow Chuckers 450, 451, 826T, 1030E, 2 plow blades. always looking for "just one more"
Old 03-29-2021, 07:45 PM
They spin anti clockwise or ccw.
Old 03-29-2021, 07:52 PM
twoton twoton is offline
What he said.
Old 03-29-2021, 10:07 PM
It is all so confusing to younger people as they only learned digital clock reading.
Old 03-30-2021, 03:04 AM
It is all so confusing to yonger people as they only learned digital clock reading
Andrew, I mean no harm with all the funnies, but that's Funny
Old 03-30-2021, 06:53 AM
ironman's Avatar
ironman ironman is offline
If the battery is connected backwards (i.e. neg to term post, pos to housing) the starter will spin the wrong way and gear will not engage.
Old 03-30-2021, 08:27 AM
And that is no joke, soo true
