Old 03-30-2021, 09:35 AM
Billy-O's Avatar
Billy-O Billy-O is offline
Originally Posted by Andrew View Post
If starter is rotating backwards it won't engage the engine won't turn. My starter has 12 volts to it but does nothing not even a click. I bench tester starter and it rotates backwards.
I'm more confused about your starter having 12 volts and that it does nothing yet you bench test it and it rotates backwards. You have some good advice here in regards to CW/CCW rotation and polarity.
However, I think your issue is rather simple and common..... make sure the wiring connections from the battery is nice, bright and tight! And the also includes the ground wire from battery to chassis. Do check the wiring even though you read 12 volts. I think not enough of that 12 volts is coming thru the wiring!
Plow blade
#2 Cart
QA36 snowthower
Old 03-30-2021, 07:56 PM
twoton twoton is offline
Yes. And if your starter works on the bench, but not in the tractor, I'd be checking out your starter relay too. Simple to do with a 12 gauge jumper wire and a test light. It's easier to get to if you remove the rear hood support. I've seen lots of cheap china relays fail lately.
Good luck.
