Old 08-02-2021, 07:00 PM
EternalArianne EternalArianne is offline
Default Kohler Command 15 OHV
Trying to find more info about the engine in my HDS 2155. Most of the info I find is about the Command PRO 15, I can’t find anything about the Command 15 OHV in this model tractor. Are they the same thing?
I’ve read the Command is considered a “commercial” line of engines, is that true as well? Just trying to get more info on this engine and it’s reliability.
Thanks
Old 08-02-2021, 07:33 PM
This is what it rolled out of the Factory with...
NOTE: The spec number should read 44523. Kohler ID's it as.." Command Pro Single "
Old 08-02-2021, 07:40 PM
Ok that model number helps a lot. So it’s just a plain ol’ Command, not the Command Pro, it seems. I don’t know the difference between the two, but I’m just glad to have a Kohler regardless. I don’t know if it’s just me, but I swear Kohler engines sound better than B&S? Or rather it just sounds “different” in a good way?
Old 08-02-2021, 07:41 PM
Oh I just see you edited and it is a Command Pro.
Old 08-02-2021, 07:52 PM
Ozcub's Avatar
Ozcub Ozcub is offline
My HDS 2155 had a Kohler Command not a Pro , the difference is not great , larger oil , air and fuel filter , platinum spark plug , High efficiency Fan and screen , and a power bore cylinder
I ran platinum plug and a larger fuel and oil filter in my old 2155 and a mate has it and 22 years later it still runs strong
Oz
Old 08-02-2021, 08:35 PM
This one has 422 hours on it and runs pretty good. I plan on doing a full tune up on it next spring (oil filter, air filter, fuel filter, spark plug, oil change). Combined with a hydrostatic filter change and I should be good for a while with this tractor (I hope)!
