Old 10-14-2021, 11:29 AM
Nightowl66 Nightowl66 is offline
Default Deck paint
What is a good paint to coat the underside of a mower deck?
Cub Cadet 100
Cub Cadet 3206
Kubota B6200DT
Old 10-14-2021, 02:01 PM
Well most anything will wear off quickly depending on what you mow/mulch,
and the type of lawn/dirt or lack of it you mow over.
Now it it is a trailer queen, paint it up real purdy because it will never be used or seen.
Some fellers use "slip plate" it is a graphite paint made to apply to things like grain wagons so crops slide easier, but it is short lived and requires seasonal reapplication.
I have also heard of fellers using truck bed liner stuff.
You are only limited by your imagination and resourcefulness.
Do let us know what works best for y'all
Personally,
I don't use anything and come this time of the year after I mulch leaves, sticks, cat/dawg critter excrement, stones and other chit I never know what it was but it makes a hell of a noise under the deck,
it is pretty shiny and polished under there.
Old 10-14-2021, 08:04 PM
Ken41's Avatar
Ken41 Ken41 is offline
I am trying 2 part epoxy paint, but it is not cheap. Going to be a while to say how good it is.
Old 10-14-2021, 10:05 PM
Ozcub's Avatar
Ozcub Ozcub is offline
Personally,
Noise cancelling headphones might be your best bets olGeorge
Oz
Old 10-15-2021, 07:20 AM
Same here.
Keep it clean with sharp blades so it will scour and it will stay clean.
Just don't mow heavy wet grass all the time and leave it set out in the grass when not in use.
Had my 54" deck off the GTX2154LE yesterday to change oil and there was only a couple handfuls around the spindles is all, the rest is shiny clean. It is stored inside always.
I might spray some light oil on it for storage but usually don't.
Old 10-19-2021, 10:34 AM
ironman's Avatar
ironman ironman is offline
I have painted a few, both top and underneath with POR 15 or KBS Rust Seal. It doesn"t last forever but it lasts longer than anything else I ever tried.
Old 04-27-2024, 08:44 AM
tclayton tclayton is offline
Default Just applied EZ SLIDE to my RZT Deck
My RZT-50 is over 10 years old and most of the enamel under the deck is gone and lots of rust. I scraped off chunks of grass, wire brushed everything, then used a grinder wheel on my drill, power washed, then went over with isopropyl alcohol to make sure there was no oil or lubricant on the metal. Then I applied 2 coats of EZ SLIDE waiting 1 hour in between coats. This is a one part solvent based alkyd loaded with graphite dry lube. As it wears it will expose more graphite. Im excited to see how this works. Here is process: https://youtu.be/ABc7g8PLrIM
