Old 12-30-2021, 07:51 AM
Farmall450's Avatar
Originally Posted by IHCubCadet147 View Post
They are not removable on the narrow frames like they are on the wide frames.
That's crazy
So a manual and a hydro would have needed different frames had they stuck with that? (I guess the stick is pretty far back on newer manuals).
Old 12-30-2021, 06:35 PM
Once they switched to the tall tunnel frame on the narrow frames after the 70/100 they are both almost the same.The 71,72 and 73 have low tunnel frames so if you wanted to remove the shifter cover you would have to split the tractor. Not so on the the tall ones. Are you confusing the seat pan as a tunnel cover?
Up to 534 and counting...
Old 12-30-2021, 08:38 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Originally Posted by Farmall450 View Post
That's crazy
It's not a Farmall, you know ...
Plow blade
#2 Cart
QA36 snowthower
Old 12-30-2021, 09:32 PM
Farmall450's Avatar
I am not, but I don't have any manual cubs for reference.
Farmall450's Avatar
Apparently not
