Old 02-02-2022, 09:15 AM
CoachKalk CoachKalk is offline
Default 1641 Voltage Regulator Question
Hello everyone,
Total newbie here but after searching through the forum, I sure appreciate the willingness to help.
I recently bought a used 1641 and after a few runs, the old rig wouldn't start. A new solenoid fixed 1 problem, but now the battery isn't charging.
I've checked the stator and am getting low 30's AC out. My question is can the output voltage be too high? I'm testing 20v DC out of the regulator. At first I was thinking awesome! But I see that it should really be mid 13's.
Before I started chasing back up to the key switch, I figured I'd check with the pros.
Any help is very much appreciated.
Steve
Old 02-02-2022, 10:47 AM
First, welcome to OCC........
The output of the V/R should be 13.5 to 14.00 VDC. The output is based on that the "V/R Housing" has a good ground. With a VOM or a DVM meter, measure the resistance from the V/R Housing to the Battery Negative Terminal. You should have Zero Ohms. If you don't have a meter, then take a Jumper Wire and jumper between the V/R Case and Battery Negative Termnal. If you see the normal output, then you have a grounding issue. If no change is seen, then replace the V/R.
Old 02-02-2022, 10:56 AM
Thank you for the welcome AND suggestion. I do have a meter, so I'll do the check you recommended.
Old 02-02-2022, 11:20 AM
0 Ohms it is! New V/R I guess. Hopefully a bad V/R putting out excess voltage doesn't damage anything else. ?
Old 02-02-2022, 01:21 PM
I am not a big fan of the Vanguard VR's. I replace them with Kohler VR's.
Old 02-03-2022, 01:04 PM
Check the voltage at the battery while it is running should be 13 to 14 vdc. If it is 20 then there is a problem.
Up to 534 and counting...
Old 02-03-2022, 04:22 PM
It's called a rectifier.
Solid state term for V/R
Old 02-03-2022, 05:23 PM
Well it does both tasks, a rectifier, and voltage regulation.
A rectifier by itself, does not regulate voltage,only change it from Ac to Dc current.
so technically it is a regulator/rectifier
Old 02-03-2022, 05:37 PM
I thought it was a rectum fire, you know, what happens when you eat Mexican food..
Old 02-03-2022, 05:45 PM
If one is not "regular" a "rectum fire" might be welcome Ha,LOL
