We tried to replace a 40+ year old door, but, because of it being brick inside and out, no carpenter would even consider the install,, even at $4,000.
SO, I removed the door, spent two days taking off the previous coats of "house paint" and repainted it. The wife picked a color,, I decided to try to mix some tractor paints that I had in the shop, and paint it with that, mostly as a primer. Well, I ended up almost perfectly matching the color the wife had chose. 50% AC Orange 35% IH Red 15% JD Green AND hardener,, I buy hardener from Tractor Supply (the paint, also) That door was painted at about 2PM,, and it was dry enough to install by 5PM. I considered the paint fully hard within 48 hours,, it was probably less. |
I just painted mine using CASE primer and paint
Was 8 to 1 ratio. 8 parts paint 1 part reducer and 1 part hardner The more hardner the faster the paint will dry. Took me close to 2 quarts white and 2 quarts yellow to do the full tractor and QA-42A. Have the deck still to do this summer I recommend of you can get a rattle can of each from case for touch ups |
| Thread Tools | |
| Display Modes | |
