#21
Good grief!!
What an abortion!! |
#22
Also looks like they removed the damaged fenders and replaced them with the fenders from probably the same 1X4 1X5 series tractor that the hood came from. Replaced the seat as well. Oh, and the hydro lift musta stopped working so someone tacked on that manual lift. If I were you I'd remove the cobble job hood and bezel and search for a correct one, as well as the correct set of fenders. Get the hydro lift working again as well. parts tractors aren't too difficult to locate. With some work I think this could be a nice really unique tractor. Don't forget to replace the engine isolator mounts. I decided to decode your serial tag too, you have a 1250 (0630) built in August 1977.
![]() '70 107 with k301 engine swap '71 106 with 38" deck '70 147R with factory replacement k321, 42" deck '61 Original with 38" timed deck '63 70 "pinkie" 1863 with 54" deck '46 Farmall H, '50 Farmall Cub 105 x2 (parts) |
#23
Might very well be the same tractor......The original poster is also from NJ!
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
#24
Thanks Cub Cadet 107, I appreciate everyone's advice. Unfortunately this one is on the bottom of the restore list. I got a 86, 76, 105, 125, 127, 147, 149 all ahead of it
#25
Why Farm Half When You Can Farmall? 1282 | 44C Deck, 42" Blade, 020" Over K301 * 1711 | 50C Deck, #1 Rototiller w/ Extensions, Sleeve Hitch, CH18S * 1811 | 46 GT Deck, 42" Blade, M18, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck * 1914 | 44C Deck, KT17 Series II * 127 * 1650 Twin Stick | 50C Deck, 42QA Snow Thrower, K341 * 1862 |
| Thread Tools | |
| Display Modes | |
